I have been working on it (not as much as I would like) just haven't been posting.
So the plan was to go with fuel injection, couldn't seem to find something that would work with the Tunnel Ram set up, so I switched to a RPM air gap for now, along with QFI's Throttle Body fuel injection system.
After I bought The QFI kit and reading the instructions I discovered that the QFI system is supposed to be able to run 2 QFI TB, but for now I'll just stick with the Air Gap for now, down the road I'll swap it out to see a difference. I think 2000cfm thru 2 TB might be a little much for the 383 though.
The shifter linkage is connected, had to get the 1-2 rod shortened, because I switched the the ball and detent side cover, the operating lever wasn't clocked right and the shift linkage was to long, couldn't find one that would work so we had to shorten it.
I'm using the QFI system to control the timing also, so I had to get an MSD distributor, that I was able to lock out the mechanical advance.
Wrapped the headers, I know they will probably rust out but I figured what the hell. Best price i found on headers are from BPE, they are actually made by Hooker for BPE,even though the collectors neck down to 2.25", I cut the collector off where it necked down and welded on a 3" flange. So now I have a 3" collector. Still cheaper than Hooker headers with the 3" collector. Sandblasted, painted with header paint on the outside, and Eastwood internal exhaust coating on the inside, so we will see how it holds up.
We got the rest of the sheet metal painted and the hood installed.
Battery is mounted under the box on the passenger side.
What needs to be finished, interior is not even close, still have a hole in the floor for the shifter that I need to finish, hydraulic clutch, exhaust system, and a couple odds and ends. Need to make my own bed cover.
Need to find an upholsterer near Reading, PA to do my bench seat, sun visors and arm rests.
