How in the world?
Generally; the NP203 is bolted onto the back of the SHORT-TAIL 727. Then the driveshafts are sent in both directions.
The GVod comes with an adapter that bolts in place at the back of the 727 maincase, then about 20inches or so of GVod, then the T-case. And you're saying that Gear Vendors has adapters for both ends AND that it somehow occupies the same space, AND, you can reuse your factory length driveshafts?
IDK man,
I have, however, seen the remote-mount GVod; but you still have to make driveshafts for it; and now you have a new problem, namely, pinion angles...........
In any case; you'll definitely like that GVod.
Happy HotRodding
