Reed
I recently got what think is a true 44,000 original mile 1982 Ramcharger powered by a 318. The truck is totally stock and was maintained at a local dealership. The truck has part-time four wheel drive and is a big heavy un-aerodynamic box.
I would like to maximize fuel efficiency on the truck since it will be my daily driver. I am not expecting to get 20 MPG. Heck, if I got better than 13 I would be happy. The truck has 3.2 gears in the axles so I am only spinning around 2300-2500 RPM on the highway. I am going to use it as a daily driver and won't be racing it or off-roading it. I am thinking that a build focused on low-rpm torque rather than high RPM horsepower is my best option for increasing MPG.
To that end, I have secured an old Edelbrock SP2P two barrel intake and a set of 1987 318 heads that are the 302 swirl-port casting. I am going to keep the stock Holley 2280 two barrel carb and the stock tiny valves in the heads. I am also going to keep the EGR functional.
My question is the cam. Is it worth it to swap out the stock 1982 two barrel cam? If so, what cam would pepole recommend for low RPM torque in a 318 running the stock small valves and two barrel carb? I am trying to keep it running smooth and just improve fuel economy and torque.
Any constructive input is appreciated and welcome. Thanks.
