Steering wheel replacement
niceolddart
S.E. Pa.
Has anyone done away with their airbag setup on the first gen Dakota? I want to get rid of mine (1995) & replace the steering wheel with a better looking, non airbag wheel. The factory wheel is UGLY & a PITA with the horn buttons on either side of the wheel. It's a splined shaft, & if I get rid of the clock spring, will a steering wheel from another Dodge match up with the splines?
If you pull the steering wheel, check the spline count and the shaft diameter. This may give you the answer you looking for.
