cindybrat7
my old trucks
Bob couldn't wait till Tuesday for a warmer day, so he bought some fast reducer and painted yesterday
I didn't know what scotch broom plants were so I googled it, wild pretty weeds, crazy, looks like snow returning in your area depending on elevationWe actually had some sunshine and decent temps today, so I figured I'd try and trim some of that pesky scotch broom (if it's around 2" base stem diameter or larger it's less likely to drop seeds and sprout back). Problem: the clutch on our MAIN chainsaw seized, so now we have no working chainsaw. One needs a carb rebuilt, the other needs the clutch unstuck. Can't cut it otherwise, our loppers aren't big enough for a lot of this stuff
They're an invasive pest all up the Pac-Northwest, they grow fast & plentiful and they're hard to kill. Slack for one year and they'll push in. They're worse than blackberries, blackberries at least have berries to offer up. In most cases they'll drop seeds if disturbed or pruned, so even if you pull a juvenile plant it'll try to drop seeds and you'll have to watch for any sprouts coming up. Mature plants are less likely to drop seeds if you cut em at the base. Removal works best in late summer after they drop seeds and the soil is too dry/malnourishing for them to recover, but you can do it early spring too if you catch it early enough.I didn't know what scotch broom plants were so I googled it, wild pretty weeds, crazy, looks like snow returning in your area depending on elevation
LOL wish I could but too much "other" burnable stuff nearby. Can't write-off the neighbor's house!How about trying a match! You could call it a controlled burn! The forestry service does that to prevent fires from getting out of hand. You might even be able to write it off as your contribution woodland preservation-LOL![]()
What does it fit? It has been a while since I have seen something with a hard line to the vacuum advanceBeen getting busy with custom distribs this one came out nice.
before and after.View attachment 12826 View attachment 12827 View attachment 12828
66 273 just did a 50 Plymouth and it has a brass 90 on it true hard line. Seems they went with that design for a while 40's to mid 60's the nipple for the rubber showed up around 62 fr4om what I can tell, order one it comes without the spring/shims/end so really just taking a guess from what I have seen. Getting busy a lot being sent to me now it is spring!What does it fit? It has been a while since I have seen something with a hard line to the vacuum advance
