65 sporty
Another beautiful day, not to hot or too humid. Around 80.
I have him top marks in the survey they sent me. But they always tell me to out in the highest rating, give them one low rating and they fail the survey, it's total BS. I've always had cool installers so I help them out when I can..Guess the Dish guy had a good day.
Take a closer look, I did a google search of a 102 and I don't think that is it.An International Cadet 102 I think is the model.
You posted while I was typing but it looks more like this doesn,t it.Take a closer look, I did a google search of a 102 and I don't think that is it.
That's why I put the I think in my reply, cause I wasn't sure. It's something 02, I'll look in the morning.Take a closer look, I did a google search of a 102 and I don't think that is it.
I have barley looked at it, it has a PTO. I pushed it, it rocks but that's it. I'll see if it's in gear, brake is on, etc. Pushing snow would be awesome, my back would be happyTractor data says 65-67, 10 Hp, shaft drive, 6 speed with a 3 spd gear trans..
If it runs and you don't have to rebuild the enter tractor it would push snow. At least it makes garden tractor statues and that's a plus. Not sure how available mower decks are for these but it would definitely handle a pull behind. That is more than a new box store will do.
Yeah, I got the 2 at the end right, it's a 282.Even though its red it sure looks like a 102. Guess a serial and model number from a tag should let you know for sure.
Other info | |
Tractor Dimensions | |
Tyre Sizes (std/options) | |
Transmission Details | |
Engine Specification | |
Model history | |
Model introduced | 1979 |
Model discontinued | 1981 |
Model status | Discontinued |
Preceded by | International Cadet 80 |
Superseded by | Cub Cadet 282 |
Engine make | Briggs & Stratton |
Engine model | 191707 |
Fuel type | gasoline |
Power hp | 8 |
Power kW | 6 |
Governed rpm | 3500 |
Displacement cu in /(litre) | 19 ci |
No. of Cylinders | 1 |
Bore in (mm) | 3 in |
Stroke in (mm) | 2.75 in |
Cooling system | air |
Naturally aspirated, Turbo or Supercharged | NA |
Transmission type | hydrostatic |
Forward | infinite |
Reverse | infinite |
Drive | 2-WD |
Linkage Category | Unknown |
Front | 13x5.00-6 2-ply |
Rear | 18x9.50-8 2-ply |
Length (inches/metres) | 62 in |
Weight (nominal) lb/kg | 430 lb |
Turning circle (nominal) inches/meters | 11 ft |
Wheelbase | 43 in |
Factories | Louisville Works, Louisville, Kentucky, USA |
Plow rating | |
Approximate Cost new in (year) | $2176 |
