Ignition switches wirin
THE-HOG
new mexico
I put whole new wiring harnesses in my 75 w100 with the 5.2 & it cranked then, put a new ignition switch in and now it doesn't crank. The switch has 2 thick wires and 4 small wires. My big wires are correct but I don't think my small ones are and I can't figure out a way to correct it.
I did some searching and found this, but you said you have 6 wires
You need to find the wire that is only hot when the key is turned to hot. This needs to be connected to the wire going to the starter relay.
