thinman666
I need help with the routing of the vacuum lines to the distributor on my 1969 F100 240hp standard transmission 2 wheel drive one barrel carb.
There are three vacuum supply points. One on the intake manifold, one on the base of the carb. and one higher up on the carb.
The distributor has two vacuum chambers. One hose outlet pointing up nearest the distributor and one outlet pointing straight away from the distributor on the very end.
I sure do need help with this.
Thanks,
Russell
Thanks,
Russell
