A few more "updates" on this build..... Not much, but something, something meaning a bit of "small"
details ready to go! I too kit upon myself, to make my own "power steering" on this model just I did on
my truck in this build, as the kit, neither of them, came factory or stock with such, and me, being me, I
LOVE details, so I just HAD to add it! With that being said, a part that came from the stock pil 'O parts
I got, I salavaged the lower power steering, that leads to the drag link.
Granted, as you can see the white is the power steering "housing", thatn I had to remove the steering
shaft from one end, and make it go on the other (NOT added here), withthat, I needed to make the drag
link, which is that metal "dog bone" detail seem here as well as "pin" it to the steering box, and have
some sort of "spacer" as well, which is out of a necklace kit I bought for numerous detailing uses....
Fittings, spacers, you name it.
Same thing different view. To show "depth" of the detail in itself. It will be mounted OUTSIDE the
drivers side frame rail! As you'll see. Remember this truck is a bit different from the common "Power
Wagon" we all know and love!
I got a bit done/added to on the frame as well. I went and am still working on the rear suspension to get
it "level" as it was all broken up.... NOW however its being done with heat! As they're solidly, mounted
in place on the frame for the rear axle! BUT, I got to thinking AFTER mounting the rear leaf springs,
what about the transfer case!? Hows that going to "sit" on a "low" 4x4 truck? As the actual model itself,
seems to have been "lifted" and I brought it back down to "family 4x4 truck" standards.... I did NOT want
the transfer case to sit so low that it was barely offthe ground, BUT to sit in such a way, it wasn't to
far up in the frame to cause alignment problems to the cab with the interior tub. SO, I got to looking a
bit and needed to make some more modifications, to the frame.
The dark gray part is the transfer case mount. The whole square inside the frame rails, and the
webbing" between the cross members had to be removed. As I needed the thickness of the frame to get the
new transfer case mount in it! And "high" enough to look right. I even went as far to relocate the
transfer case "cross member" mount, to the HIGHEST location of the locating blocks on the insides of the
frame rails. To look as an "angle" mount from the cross member part of it, (if any of this makes sense)
Then while messing, I went to "sturdy" up the rear leaf springs. These things were/are brittleas they're
old, and I MEAN OLD, and were from a Glue bomb I mentioned I got for mere parts.
A LOT of little things, to allow me to move on to the bigger things.....
MORE to come just after these brief messages!
