78 dodge d150 318 automatic instrument cluster, is it possible to rebuild it some how?
Rude Robert
S. California New home in Keene, Tx
Just asking if there were any after market gauges that would fit into the same format of the original configuration? Or is it just better to put some gauges in there and make them work just to keep it easy?
You can find aftermarket gauges that fit the original spots in your truck. These gauges are made to match the size and shape of the factory setup, so they fit without much modification.
However, if you can’t find a direct fit, you can install different gauges and use adapters or custom mounts to make them work. It’s up to you whether you want to keep the original look or go with something more flexible.
