Today was a baby step back into painting. It has been a few years since I painted a whole car. Some habits you develop by
feel where you just find your own way, a way that works for you. I’ve said for years that one difference between a newbie and a professional is that the pro knows how to make corrections along the way to keep moving forward. The newbie often makes mistakes and cannot overcome them while a pro knows ways to adjust to a changing condition. I had some mistakes today but all in all, it worked out pretty good.
I have 3 1/2 quarts of paint. It mixes 1 to 1 with reducer so that 3 1/2 quarts equates to 7 quarts of sprayable color. Sometimes when you have a spotted panel like this:
You have to expect to lay down several coats to make those spots hide and get an equal color across the whole panel. I don’t know if it is common to just spray the spotted areas several times then go over the whole panel with 2 or 3 coats. What really matters is that once it is done, the color is even and no primer spots can be seen.
For clear, I had 2 quarts. Those mix 4 to 1 to 1/2.
Clear.
Catalyst.
Reducer.
This means each quart when mixed is 32 ounces + 8 ounces + 4 ounces for a total of 44 ounces, about 1 1/3 quarts sprayable. I needed more clear.
A quickie body and fender shop will have a clean, dust free and
bug free spray booth and experienced workers that can lay down paint with minimal flaws.
That isn’t me. I’m out in a semi rural area with some dust, some bugs and add to that sweat and eyelashes. Stuff falls into the freshly sprayed panels sometimes.
Body shops may spray and then send the car down the road with no sanding and buffing. Most production cars and trucks have some degree of orange peel anyway. My truck had some repairs to the body years ago and those areas had orange peel.
The hood scoop came out nice enough to install as is.
The grille too.
The tail gate looks okay in pictures but has some flaws to correct.
