niceolddart
2001 Dodge 2500, 2wd V10. Where is the transmission control computer located on these trucks? Does anyone do a quality re-man on these if I need to go that route? Long story, but trans has been acting up, not shifting, slipping, shifting late etc. I have changed the fluid & filter 3 times so far & that seems to cure it for a bit. Seem like the filter gets plugged up, & after I install a new filter & fluid, it works fine for a while.
I figure this time I'll check the band adjustment, shift solenoids (They have been replaced at one point before I got the truck) & any grounds that may be loose but don't know where the controller is, without really looking for it. I'm sure someone here knows. TIA
P.S. I did have to replace the radiator because the trans cooler inside the radiator was leaking into the coolant & vise-versa. It has the factory auxiliary cooler next the radiator also. They don't have T.C. drain plugs anymore (I checked this one just in case) & I wanted to flush the whole system out but couldn't.
