If there's one thing these old Diesels are famous for, it's their ravenous appetite for Voltage Regulators! They just can't get enough, they're never satisfied.
Well, I can't afford keep replacing VR's every other thing, so I had to do something about this little problem.
As I suspected, there were so many shorts and bad connections in old the electrical system, due to old dirty connections & connectors, that it was reducing the voltage to the VR, causing it to remain in an active state all the time, which is why the cheap over the counter units were frying on a fairly frequent basis. Even a heavy duty Transpo unit held out for as long as it could, but eventually lost the battle.
That said, I decided to install a Relay in the system that would relocate the voltage sensing circuit of the VR from the weak (under voltage) ignition circuit, and move it directly to the Battery.
To do this I had to locate the main ignition circuit splice in the wiring harness. Then locate and separate the two required charging circuit wires from the splice, and wire them to the relay as illustrated below. I ran the wires through the wiring harness to keep it neat. Then I ran a seperate hot and ground from the relay to the battery. Problem solved...
The gage for the Charging System holds steady at dead center now. This is the first time since I've owned the truck that the gage has read correctly. Previously it had always leaned more to the charging side, sometimes more than others, but always to the charging side. As you might expect, the battery would often get quite warm as well.
I eventually got in there and took care of all those pesky electrical connections that were drawing down on the system, and causing erratic behavior issues, so that's all good to go now as well.
I also relocated my VR from the OEM Death Valley Hot position just above the Exhaust Header, to a much cooler position over at the fender wall just below the hood hinge. It's pretty much common knowledge that electronic voltage regulators do not last long when mounted near any source of extreme heat.
Wiring Harness Splice Location
Relay mounted on fender wall near battery
Perfect output at gage
VR relocated to fender wall.
