I can at least access Mitchell at the library. Now to find time to get there. I can e-mail to myself and avoid printing fees.
I think they were all the same but don't quote me on it. By any chance does anyone know If you can swap a electric speedo for a mechanical one. The more I dive In to this truck the more electrical problems I'm finding. It's really starting to get disheartening. I mean I really don't want to do a whole re-wire job. I have a 21 circuit universal harness from sumitt that I've had laying around for a while. It's just that I'm working outside and It Is not fun when you have absolutely no shade from the sun down here In S.C. It's been 100+ heat index for the past 2+ weeks. I can usually get started by 8-830 and knock off at 1-2 before the real skin melting heat gets going.Dodge mini van fuel filters are good for that on preinjected engines. I will also be checking my tub of injection parts to see if the air pump is there. I just don't remember there being one on the 89 engine. But it was extracted form a 350 vans if it makes a difference.
The gauges will work except for the speedometer. The one other thing Is the OD. I have the A518 with a non lock-up converter. So all I think I might need Is to wire a switch to ground and be done for the OD to work. Am I thinking right on that or not.Give it a try but will the gauges still work in the original dash once the computer is gone?
I know the system my 87 D150 has It. This doesn't. The cruise Is controlled thru the sbec and vacuum. I just did talk to the tech. dept. over at PATC and he told me that the early A518's speed sensor worked with a spline just like a speedo does and, all I have to find out Is hole size. I have a gauge cluster with a cable drive so all Is good. Now I just have to workout the OD.The speed sensor between the speedometer cable and transmission input is for the cruze control..........unplug it the cruze control won't work but everything else will.
