Streetloaf440
1989 D150 440 swap Shop Truck.
1989 Dodge D150 LE
1971 440
Steel crank
TRW Pistons
Mopar 484 purple cam
Edelbrock E street aluminum heads
Edelbrock RPM intake
Edelbrock 800cfm AVS2
Harland Sharp adjustable roller rockers
Smith Brothers pushrods
MSD ready to run distributor
Milodon 8 quart oil pan w/ windage tray
Champion 3 core aluminum radiator
Hooker headers into 3” exhaust with dual in/dual out Magnaflow muffler
Rebuilt 727 with shift kit and +2 quart Trick Flow aluminum trans pan.
Hughes 24-20 converter
5k miles on trans
Ford 9” narrowed with Moser bearing ends
Strange 31 spline axles
3.5 gears with Detroit Truetrac
2500 miles on rear end
Front suspension is lowered on van lower control arms with Viking Warrior Coilovers
1” front sway bar
Stoptech slotted rotors
Powerstop pads
15x7 aluminum slots with 235/70’s
Rear suspension has 2” drop shackle and helper leaf removed for around a 4” drop
1” rear sway bar
15x10 aluminum slots with 275/60’s
Interior has been sound deadened on floor, back of cab and doors. Has new carpet that needs to be installed. Brand new weatherstripping installed.
Solid driver but does need paint, see pictures. Or drive it as is. Mopar decals are just magnets and can come right off. Been a fun project, but ready for something different.
$13000 obo. May consider trades or partial trades plus cash if your trade is worth less. Have plenty of extra parts that can be worked in for the right deal.
Located in Jefferson County WI.
1989 Dodge D150 LE
1971 440
Steel crank
TRW Pistons
5k miles on trans
1” front sway bar
Powerstop pads
1” rear sway bar
