Markzilla8
Rest assured the exhaust is on its last leg lol It's barely hanging in there. Parts of a mouse nest came out of the passenger side exhaust pipe earlier today
Exhaust leaks !? Did you "see" his mufflers ! ?Have you checked for exhaust leaks?
Yup, Yup and, Yup. make sure basics are spot on. Then go deeper if needed to.By the way , welcome to FTO . You might want to check your wires again and make sure there not arcing off of a manifold or each other or anything . Also in the future I'm with Mob and use Champions in a Mopar . Not saying this is your issue now , but just saying . By the way , What did you gap your plugs at ? Also for future reference with the timing . Bring your #1 piston up to top dead , check your balancer and the line "should be" at 0 on the pointer and your rotor "should be" at #1 in your cap . That's a good starting point .
I had an old Jimmy that the rear brakes never worked, as I found out when a brake line blew. I got to pay $140 for the guy to cap a line after beating the daylights out of the drums to get them off. My brake pedal did have a good firm feel to it though. I hope those adjusters help bit I'm not sure if that's your current issue.I bled the master with it on the truck but did the same thing you mentioned to do (have done it 3 times now to be sure)
I'm kicking myself now... When I redid the rear drum brakes I threw the old adjuster screws back in there bc I wasn't sure what they did... They are frozen solid and won't extend at all.. So the drum and wheel would spin freely. I've got 2 new ones on order. Hopefully when their in and adjusted my brake pedal will be fixed
Awesome! That's got to make you feel better.I installed the adjusters today, the pedal feels way better! Haven't been able to take it out on the road yet, just a short ride up the driveway and it felt good.
Here's to hoping their squared away
