Chisel worked great, thanks 7mopar. Hub/drum was going nowhere, so I had to bolt a chain to the lug studs, then hook a tow strap to the chain, and hook the other end of the strap to the rear suspension of my car, and put it in drive...it worked. The bearing went flying like 5 feet. I won't be able to do this trick on the left rear if it's stubborn; no access where this pig is parked. If it's really stubborn, I may have to fab up a puller. The puller I used on the front won't work because that hub that the axle anchors to interferes,
MT
