WANTED Wiring harness
volaredon
Illinois
For 83 d250. I think 81-84, maybe 85 are the same.
Looking for the actual engine wiring harness that connects to the rest of the engine bay harness at back by firewall near regulator, for v8. It plugs into an 8 blade connector back by voltage regulator. The loose ends go to alternator, temp sender, choke coil, distributor, coil, etc.
Also any wiring pertaining to factory ac on these trucks. Not sure if whole harness is different or if the AC is an "overlay" deal
Have a truck I'm putting back together from scratch, 83 frame, 90 cab, 91 bed, 88 core support, etc. all rust free
84 was a sea-change year for Mopar across the board, a lot of little things. But just that part should be the same, 100 amp alternators will have a different connection. The A/C compressor might feed in from the main harness off the right fender attached to the A/C hoses. I don't have a clear enough picture of that to know for sure. But the early 80's usually had a seperate harness for all the A/C components that plugged in to the main harness (near the heater box if I recall correctly).
When I put the 84 harness in my 85 the only thing I had to do was to release a couple of terminals in the engine side and swap them to some previously open unused terminals as they moved the wiper power location between those two years. Has nothing to do with AC though. I am adding factory AC to the 85 and haven't gotten into the wiring part of it yet.
Gonna be putting my old 83 back together with rust free sheet metal. That's what I'm needing what I'm asking for.....the rest of an 83 harness minus the actual engine part
