Hello Iam looking for upper controj arms 1989 d 150. Are there able to be swapped with other series B w or only for d series Any ideas of suppliers in canada thanks Brett
Couldn't tell you about the B series , I'm not sure if vans used the same control arms . The W series ( 4x4's) didn't have control arms . But I would think any D series ( 2 wheel drive ) from the mid seventies up to 93 would work . Sorry can't tell you about any suppliers up in Canada . Hope this helps helped and by the way , Welcome to the site , hope you stick around for a while Brett .
For ease of interchangeably I'd stick with 1st gen trucks. 1983-1993 upper control arms are the same. They'd need to be from a D100 or d150. Or a ad100, or ad150. You need to stay with 2wd for obvious reasons. The 1/2 ton trucks, and 2wd ram charger will have what you need. The earlier trucks had a different wheel bolt pattern, and I'm not sure if the control arms are interchangeable. I wouldn't try the vans, you don't want a part you can't use. Good luck in your search.
