WANTED Slant 6 bellhousing
magnumforce87
Hollister, Ca.
Hey guys, I got a dodge w200 powerwagon, doing a slant 6 turbo project. I’m looking for a slant 6 np435 bellhousing, flywheel, clutch, and pressure plate. Or would a flywheel, clutch, and pressure plate work of a small block set up? Thank you.
Will have to be from a slant 6, may be some crossover on flywheel and clutch, I've not looked at those, but the bellhousings will not interchange. And it's not a real common unit, had one for years and finally sold it a couple years back.
What year? Flywheel center hole changed size from 1967 (small hole) to 1968 (large hole). One bolt hole would need to be "slotted" on a V-8 flywheel for use on a slant. Same situation applies to the center hole for the small block flywheel. Can't use a 360 flywheel (balance situation).
