PH27L7
This is a Mopar A833 aluminum case overdrive transmission & associated parts. They were removed from a 1981 Dodge D150 with slant six many years ago & stored indoors, they are low mileage and in unmolested, excellent condition.
Included as pictured are:
Transmission with C-13546 B aluminum main case & shift cover, C-9953 iron tail housing with dual shifter mounts
Bellhousing- Aluminum 4202506, includes fork / boot & steel inspection cover
Flywheel, 122 tooth 2128290
Pressure plate & disc, Borg & Beck 10 inch
Shifter rubber boot with chrome trim ring & fiberglass floor mount
Hurst shifter, special as used only with OD transmissions, includes rods / levers / mounting plate
Z-bar with clutch pedal & rods
Throwout bearing
Misc hardware
Hardwood shifter ball (aftermarket)
$400 takes all
Also have a rebuilt original 10 inch pressure plate & disc for $80 (not shown)
May deliver or meet in a limited radius around Pittsburgh, PA, prefer not to ship.
Throwout bearing
Misc hardware
$400 takes all
