Aussie Challenger
I have an unusual problem with my headlights on my '79 LRE, remember they have 4 headlights.
When vehicle arrived here in Australia the headlights worked OK but due to the fact we drive on the other side of the road I had to replace the H/L headlights, high beams are OK.
I fitted Quarts Halogen lights and fitted 100/75 globes, when lights now are on low beam the second set of original high beams lights glow dull, appears to be a ground return feed, I fitted extra grounds. Checked to see if the dip switch was feeding current which it is not. I changed lights back to originals and problem went away, fitted new lights and problem reappeared, checked terminals on new globes with originals, they are the same. Bought and fitted a second set of globes different brand, same problem.
I was going to fit relays anyway which I usually do first, so installed 3 relays running one for low beam, one for the right side high beam lights (both of them) and the third for the left side high beams. Still have the problem.
I have fitted hundreds of relays over the years, did the same to my '70 Challenger (almost the same wiring layout) with no problems but this has me stumped.
Short of cutting the wires completely out and rewiring completely, I actually ran an extra wire to the high beams on both sides to allow for the extra current, have wired in extra ground wires both sides.
Anybody had a problem like this, my usual auto electrician is out of the country for a while and other mechanic mates have never heard of this type of problem before so I have nobody I can ask?
