conversion to automatic transmission
bkuster
ky
i just bought an89 d100 with a 5 speed manual transmission. i prefer automatics and have located a transmission. is it extremely difficult to convert to an automatic? will i find linkages and shifter fairly easily? any other pitfalls? also, i am considering a mild lowering of the truck but do not want to satisfy ride quality... there don't appear to many kits available. any advice?
If you want a column shifter, you will need a different column and the linkage. You will also need the TV linkage or an aftermarket cable kit. Like the one from lokar. You could go with an aftermarket floor shifter. I have seen guys talk about lowering and the B van lower control arm swap seems to be the way to go
89 is EFI, that will require a computer swap to run right. If you put an overdrive trans in then there's all the extra modules/modules that go under the dash too.
If he gets a trans 95-older there isn't much "computer control" needed. Can do both functions by toggle switch
I just put a complete 90 drive train in a 73. There is an extra module under the dash for the automatic (not there with the 5 speed 90 I had) AND the OD stitch is also a minor processor that controls that function. Because starting in about 88 adaptive shifting became a thing, essentially it kinda learns your driving habits and adjusts some of the shifting behaviors accordingly.
Making something simply function or work right are two different things.
I want nothing to do with efi. Not the Dodge throttle body setup anyway. Carbs are much less headaches for me
Did not take full effect in Chrysler vehicles until 2001 I believe. But could be wrong. I have 1993 and 1999 overdrive units that can still be switched off and on.
