78 dodge d150 318 automatic instrument cluster, is it possible to rebuild it some how?
You can find aftermarket gauges that fit the original spots in your truck. These gauges are made to match the size and shape of the factory setup, so they fit without much modification.
However, if you can’t find a direct fit, you can install different gauges and use adapters or custom mounts to make them work. It’s up to you whether you want to keep the original look or go with something more flexible.
