2010 vibration
pagilman
farmington,pa silversprgs fl
My hemi crew cab has a vibration through the throttle pedal and steering wheel. This usually is noticable at 35 to 45 mph not at highway speeds, tryed working with the tires but that didn't help. just had the tie rod recall performed with no differance, any ideas? Walt:fencing:
They've been balanced several times and they told me the rims are true, seems to be getting worse. That maybe a good thing. then I can find out what it is, Walt
I wouldn't be at all surprised it's the tires,despite the fact that they're balanced !! The plies do separate !!
Check your shafts, sounds as though a joint or you have a shaft that lost a balance weight.
Tires with bad belts will not be able to be driven thru to a higher speed and feel better, a shaft out of balance can or a bad joint.
